1951 Ford Victoria
rlawry |
11-15-2019 @ 12:53 PM
Does anyone know where I can get a 6 volt, 2 speed blower motor (heating system) for a 1951 Ford Victoria ? All I'm able to find is generic single speed motors. Thanks. Rick
37RAGTOPMAN |
11-17-2019 @ 3:12 PM
hi 51 Ford you should have a 2 speed switch, or a variable switch using resisters , in the dash check your heater switch to see what you have, what wrong with your motor, it may only need freeing up, stuck from sitting,? I think all heater blower motors are controlled by a switch, my 2 cents 37RAGTOMAN post a photos of your blower motor
rlawry |
11-18-2019 @ 4:40 PM
Hi 37RAGTOPMAN, When I got my car, the person that I bought it from had a working 2 speed,12 volt motor installed. ????? My car is still 6 volt and I have no plans of changing it to 12 volts. The car has a working 2 speed switch, so I now need a working 2 speed 6 volt motor to put in place of the 12 volt one that should not have been there. If I cannot locate a 2 speed motor, I may have to use a generic single speed motor and create a second speed using a resistor. Thanks for trying to help. Regards, Rick
TomO |
11-19-2019 @ 8:36 AM
C&G lists one in their catalog https://cgfordparts.com/ufolder/fordpart.php?number=B6C-18527-A Rearcounter.com says Dennis Carpenter has 2 of P/N 1A-18527-A in stock https://www.rearcounter.com/1A-18527-A-parts974984.html You might also look for a small motor repair facility to see if they can convert your motor to 6 volts. Some generator shops will also do it. 37ragtopman, the 1951 Ford has a 3 lead 2-speed motor that uses a change in field strength to control the speed of the motor, not the resister type used from the 1930's to the 1950's. Tom
This message was edited by TomO on 11-19-19 @ 8:57 AM
37RAGTOPMAN |
11-20-2019 @ 6:18 AM
hi 1951 Victoria what I found in a original FORD parts book [ July 1950 ] is the switch should have a according to the book it says, part # OA 18578-D switch with bulb -rheostat type and the photo of the blower motor only shows to wires coming out of it, so I assume one is the hot wire and the other is a ground, if blower motor runs back ward, reverse the wires it is a DC motor hope this helps 37 Ragtopman
rlawry |
01-20-2020 @ 4:53 PM
Hi, Thanks for the help. I finally settled for a single speed generic motor. When coupled with a switch from a '49 or '50 car that has a built in resistor allows for the second or low speed. Thanks, Rick
sarahcecelia |
01-22-2020 @ 8:34 AM
I have the original Ford two speed switch if you need one, for sale.
Regards, Steve Lee
sarahcecelia |
02-03-2020 @ 9:15 AM
I have a N O S (2 ) speed heater switch for a 1951 Car for sale. Send me a private message with your phone number and time zone if you are interested in it.
Regards, Steve Lee
sarahcecelia |
02-03-2020 @ 9:18 AM
I'll bet that Chris Robbins in Germansville , Pennsylvania has one! There isn't much that he doesn't have!!!
Regards, Steve Lee
