37 King pins
Zero |
06-02-2019 @ 1:38 PM
On 37's I read that the king pin bushing goes between the bottom of the spindle and the axle. My question is where would I put a shim if needed? does it go on top of the bushing or below it? Also, are the castle nuts on the front spindles and the back axles torqued to a certain level? As always, your knowledge is very much appreciated. John
37RAGTOPMAN |
06-09-2019 @ 11:23 AM
HI John it should go under the bearing, to keep it firm . so no up and down play, if my memory serves me right, hope this helps, 37 RAGTOPMAN
trjford8 |
06-09-2019 @ 5:22 PM
I agree, under the bearing.
Zero |
06-11-2019 @ 8:30 AM
Ragtop and TR, thanks for the info. a few more items and the 37 should be back on the road. John
