EFV-8 Club Forum / General Ford Discussion / 34 Three Window Coupe Rear Window
Posted By Discussion Topic: 34 Three Window Coupe Rear Window
stan white
02-28-2019 @ 7:47 PM
How do I remove my rear window glass?
03-01-2019 @ 5:44 AM
hi
I assume it has a roll down window ?
is it a restored ?
usually you have to remove the inside panel below the window to see what to do is needed next
more information is needed,
my 2 cents 1937 RAGTOPMAN
This message was edited by 37RAGTOPMAN on 3-1-19 @ 8:13 AM
03-01-2019 @ 6:58 AM
Ragtopman is correct. The drip pan under the window has to be removed. Are you just replacing glass or have a problem with the window regulator or glass channels??
stan white
03-01-2019 @ 7:40 AM
Just replacing glass and channel.
