V-8 Times article search
37 Coupe |
10-10-2009 @ 6:36 AM
Has anybody a better recall then me to find an article or two in past V-8 Times by John Shelor I beleive from Virginia? Articles were on coils and distributos. I have looked and looked in index and issue by issue,I have every one from when I joined in 1971. Do not think it was that long ago,mayby within last ten years.Has anybody had one of his coils or distributors?Think he modifies dist.for mre advance and uses a different point plate.Anybody know if he still does this?or anything about him?good or hopefully not bad.
efv8 |
10-10-2009 @ 7:49 AM
Administrator
You can try to look in the V-8 TIMES Index inside this site! Go to V-8 Times / select Searchable Index and type in your search words. Give it a try. Website Administrator
37 Coupe |
10-10-2009 @ 11:10 AM
Got it! thank you.Found it under coil moisture.Wasn't as long ago as I had thought 2005 and a follow up 2006. The article and the man always immpressed me,also found at about 80 years old he is still involved in rebuilding distributors and drying out coils. Thanks again,sure easier then the printed index.
