EFV-8 Club Forum / General Ford Discussion / 41 Coupe Rear Window
Posted By Discussion Topic: 41 Coupe Rear Window
smokinjoe
10-16-2016 @ 8:52 AM
I have a 41 sedan coupe and had to pull the rear window out so the new headliner could be installed. I cut the seal and the glass was on the inside of the meatal lip on the body, is that correct or should it be on the outside ? I'm not sure if that was correct. Should I use a sealer when reinstalling the glass and seal? Any help or ideas on how to put this back in correctly will be greatly appreciated.
Thanks
Joe
10-17-2016 @ 8:05 AM
Here is a link to instructions to install the glass in your car.
http://www.vanpeltsales.com/FH_web/flathead_drawings_body.htm
Check the new seal carefully before installing it. Some of the reproduction seals are made wrong. Look under the Mercury topics for Lens47 post on this.
This message was edited by TomO on 10-17-16 @ 8:08 AM
