EFV-8 Club Forum / Light Commercial Truck Discussion / 39 flathead -are RH LH/ heads interchangeable??
Posted By Discussion Topic: 39 flathead -are RH LH/ heads interchangeable??
callbald
09-28-2015 @ 5:45 AM
I was told there is no funtion/fit difference between the RH and LH heads and in that Ford sometimes put the LH 81A-6050 heads on both sides.
Sounds nutty to me. the heads do look the same with center water outlets, water temp ports on the same side, bolt patterns
alanwoodieman
09-28-2015 @ 1:11 PM
heads will work on both sides, to be correct the numbers on the heads should face each other at the rear of the block
