EFV-8 Club Forum / Light Commercial Truck Discussion / 1951 F-1 Ford Pickup
Posted By Discussion Topic: 1951 F-1 Ford Pickup
Big Red
05-02-2015 @ 5:05 PM
I purchased a 1951 F-1 Ford pickup, and when I bought it, the steering seemed loose. My mechanic said the steering gear was worn, and I ordered a rebuilt unit which he installed. The replacement is no better. When driving on a very flat highway, it holds the track well, but there is play in the steering wheel. When driving on a highway that has been used years, and has ruts in the pavement, the truck will wander when it gets on the high side of one of the ruts. I had the front end aligned, according to the manual. Any suggestions? Big Red
05-02-2015 @ 5:24 PM
Did you replace any other of the steering components besides the steering gear? How old are the tires? Are they radial or bias belted?
Big Red 51
05-04-2015 @ 11:51 AM
Sounds like you have a classic reaction caused by bias ply tires. That's just what bias ply tires do. If you have steering gear play, that can be adjusted if components are ok. Don
Big Red
05-07-2015 @ 6:40 AM
The truck had radial tires when I bought it, and it had a wander to the steering. I replaced the steering gear, and put 6:oo X 16 bias tires on, and had it aligned. No other steering components were installed. Mechanic said they were ok. It still wanders.
Big Red
05-07-2015 @ 6:42 AM
I bought it with radial tires, and it had a wander. Put new 6:00X16 bias tires on, had it aligned, and put rebuilt steering gear on, and it still wanders. Thanks
05-08-2015 @ 9:57 AM
I realize your mechanic said that everything was O.K., but a little wear in each component can cause sloppy steering. Also on these old trucks worn spring shackles can cause a lot of steering problems.
05-09-2015 @ 7:19 AM
To check for worn parts, read my post in the following topic.
https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8305&keywords=shimmy
Big Red
05-24-2015 @ 7:12 AM
Thanks guys - I'll do more exploration. Big Red
