Light Switch
witt9391 |
02-19-2014 @ 10:43 AM
My last post was incomplete. I need to know where the wires attach on a 52 f1 headlight switch
supereal |
02-19-2014 @ 1:14 PM
I am attaching a scan of the manual for your truck. It is actually for a '53, but I believe your '52 will be the same headlight switch.
witt9391 |
02-19-2014 @ 2:22 PM
thanks super
witt9391 |
02-19-2014 @ 7:31 PM
I can't tell which post is the hot wire from the switch
supereal |
02-20-2014 @ 7:37 AM
According to the diagram, there are two inputs to the switch, one from each pole of the circuit breaker. If your truck doesn't have the old style breaker, the two terminals are fed from the same source. The headlight switch is not connected to the ignition switch, but powered all the time. Circuit breakers were used due to the large current required for the headlights.
supereal |
02-20-2014 @ 7:38 AM
supereal |
