How to Remove Headlight Trim Rings ?
ersatz |
07-09-2010 @ 5:11 PM
I'm replacing the painted headlight trim rings on my 46 PU Truck with stainless rings, but running into a problem trying to remove the existing rings. Once the retainer screw is removed the ring will turn left or right freely, but will not come off. Not sure if I should pry the ring off, or what? Any ideas?
trjford8 |
07-09-2010 @ 8:00 PM
Push upward with the palm of your hand and it should snap off.
ersatz |
07-10-2010 @ 6:35 AM
Got 'em Trjford8! The first one gave me a little trouble, real tight tolerances! But once I saw what I was up against underneath there was no problem. Actually, the stainless steel rings installed easier. Thanks for the HELP!
