EFV-8 Club Forum / General Mercury Discussion / power top fluid
Posted By Discussion Topic: power top fluid
angus
04-04-2015 @ 5:26 PM
hi all what fluid does everybody use in power tops these days .I have a 1948 mercury convertible thanks
04-05-2015 @ 7:39 AM
Brake fluid was used in the system originally.
Tracker
04-06-2015 @ 2:22 PM
Hydro e electric recommends ATF rather than brake fluid...works great in my original 1951 top motor.
angus
04-07-2015 @ 1:37 AM
thanks for the feedback will use atf I think
thanks very much
04-07-2015 @ 10:12 AM
I would flush the system with alcohol before changing the type of fluid. This will remove most of the brake fluid in the system.
I use brake fluid in my 65 Cutlass convertible, because I did not want to rebuild the system and do not feel comfortable mixing even a small amount of brake fluid with ATF..
angus
04-07-2015 @ 2:44 PM
hi thanks tom will give it a good flush out before I go to atf
thank again angus
Kalee
04-20-2015 @ 4:50 AM
http://www.solitairechamp.info/
This message was edited by Kalee on 12-31-15 @ 9:06 PM
