EFV-8 Club Forum / General Mercury Discussion / oil pressure gauge
Posted By Discussion Topic: oil pressure gauge
angus
09-29-2014 @ 1:07 AM
hi all I want to put a manual oil pressure gauge in a 1948 ford with a 59ab in it I can not put a tee where the sender unit is on room can I take a sender reading on the line that runs back to the oil filter thanks roger
happy
09-29-2014 @ 4:00 AM
The 1940 handles are similar, except the coating is blue. I cleaned the handles and sanded them with 800 wet or dry paper to get an even sheen on them.
happy
ken ct.
09-29-2014 @ 4:26 AM
You can if you use the right plumbing pices. [rear] Short 3-4" long brass nipple and a "T" fitting. Ive done it on mine. It rasises the SU up higher and out of the way. Also easier to replace when its up higher. OMO ken ct.
09-29-2014 @ 6:55 AM
The return line from the oil filter does not have full oil pressure on it.
ken ct.
09-29-2014 @ 7:44 AM
The gauge has to go into the feed line to the filter. Either one of the 2 holes at the rear of the block or just before the restrictor fitting at the inlet to the filter / ken ct. Some adaptor fittings will make this work.
angus
09-30-2014 @ 12:25 AM
hi thanks for your help .Tom will I get right reading from the pipe that runs from back of the engine to the filter ? not the one that runs to the sump thanks roger
10-01-2014 @ 6:50 AM
Kenct has answered your question.
angus
10-01-2014 @ 11:34 PM
hi thankyou all for the help .I am going to put it in the line to the filter from the back of the block thanks roger.
