EFV-8 Club Forum / General Mercury Discussion / Crankshaft oil cleanout plug
Posted By Discussion Topic: Crankshaft oil cleanout plug
bbrust
08-30-2010 @ 10:07 AM
Does anyone know where I can find oil cleanout plugs for my 51 Mercury crankshaft? Joblot carries them for the Ford but not Mercury.
Thanks, Bob
08-30-2010 @ 2:17 PM
you would think they would be the same.
but also you can try other FORD Venders or a auto machine shop that regrinds shafts.should have them,
hope this helps 37 RAGTOPMAN an KEEP ON TRUCKIN,,,,,!!!
supereal
08-30-2010 @ 3:44 PM
At our shop, we open all old crankshafts to clean the oil passages. Most are nearly blocked. We then thread the holes and install new Allen head plugs, which are available from full line parts places. We go an extra step and put the crank on our balancer. You are probably ahead to take the crank to a good shop that can at least jet spray the thing, and install sealed plugs.
This message was edited by supereal on 8-31-10 @ 6:51 AM
08-31-2010 @ 9:32 AM
The plugs are not the same as the Ford. The clean out holes are larger in the Mercury crank. I would strongly recommend that you follow Supereal's advice, It may save you some agony later.
bbrust
08-31-2010 @ 4:08 PM
Thank you all for your suggestions. I believe that I'll try threading the holes.
Thanks, Bob
supereal
09-01-2010 @ 7:54 AM
Be sure to fully flush any cuttings produced by the drilling and threading procedure, or bearing damage is sure to result. Use a good sealer on the plugs, as well.
