EFV-8 Club Forum / General Mercury Discussion / 1947 Heater Motor
Posted By Discussion Topic: 1947 Heater Motor
lasmith03
01-22-2020 @ 5:37 PM
I've read the other posts on this topic but didn't find and answer.
I have a 47 Merc Conv.
We are converting the car to 12V neg ground.
The heater motor in the car is a newer 2 wire 6v motor in the old 4 wire heater box.
The switch is the original 5 speed switch - off, heat fast and slow, def fast and slow.
Does anyone have a part number or source for a 12V 4 wire / dual speed motor that I can wire up to the original switch?
I don't really want to use a voltage reducer if I can help it because of the heat load.
Thanks,
Lance
alanwoodieman
01-22-2020 @ 6:48 PM
use a voltage resister but put it in the air stream for the heater, it jus helps add BTU's
01-23-2020 @ 9:39 AM
Why are you converting the car to 12 volts? Unless you have a special need, it is better to leave the car at 6 Volts.
How much do you use the heater? Occasional use for short times (15min max) would probably limit the harm done enough for the motor to last a few years. Other than that, I would have the motor converted to 12 volts.
You could also rewire a 12 volt brush motor to use with your switch.
