EFV-8 Club Forum / 1940 Ford Discussion / Tail lights:
Posted By Discussion Topic: Tail lights:
fortyford
09-05-2015 @ 8:25 PM
One of my tail lights and brake light is a bit brighter than the other.I have tried different bulbs with no luck.What is the best way to pin point this problem?I am guessing maybe a weak ground problem?
CharlieStephens
09-05-2015 @ 8:48 PM
Run a wire from the ground side of the battery and touch it to each light socket. If the dim one gets bright you know you are on the right track.
Charlie Stephens
09-06-2015 @ 9:23 AM
It may be the lens. Some lenses are darker than others. If the ground test did not make a change, remove bot lenses and hold them up to a light source. If one is darker than the other, look for a lighter lens. If they are the same, look at the housing to see if they match in color.
shogun1940
09-09-2015 @ 4:20 AM
paint the sh*ll bright white it will refleck more light
fordv8j
09-11-2015 @ 7:06 PM
not sure about a 40,but on our 38 the tabs on the bulb are straight from each other..so you can have the bulb in wrong..done that
