front bumper brace grommets
donnicoli |
07-02-2015 @ 1:16 PM
the front bumper brace grommets are wider on two sides. do the wider areas go to the outside and bottom?
kubes40 |
07-02-2015 @ 1:34 PM
Yes - outside and bottom as you thought...
donnicoli |
07-02-2015 @ 2:21 PM
Thanks Mike, now I can put the bumper on, just the hood left, I'm sure that will be fun! and I'll probably have ?'s. Don
TomO |
07-03-2015 @ 5:57 AM
You may have to make some adjustments in the fenders and grill after the hood is installed and aligned to the cowl. I aligned the hood before I tightened the fenders and then made adjustments to the fenders to fit the hood. Tom
This message was edited by TomO on 7-3-15 @ 6:00 AM
donnicoli |
07-03-2015 @ 3:56 PM
Tom, thanks for the tips, it fit before, I have my fingers crossed! Don
std1940 |
08-16-2015 @ 3:31 PM
Is that same on rear? Wide out & bottom? Thanks Tom.
Rustynutz52 |
09-20-2015 @ 6:34 AM
Kube, Are these shown with the correct orientation in the photograph. It sounds like per your written description they are correctly oriented. If so I installed mine perfectly backwards last week. Thanks Mike
