Head bolt torque reqts
classiclover |
09-11-2021 @ 10:56 AM
I am cleaning the car body to engine ground strap. Do I need to return the nut to original torque If so, what is the correct torque Thanks Dale
kubes40 |
09-11-2021 @ 1:33 PM
quote: I am cleaning the car body to engine ground strap. Do I need to return the nut to original torque If so, what is the correct torque Yes, you should re-torque the nut. What spec? Depends on aluminum vs. steel heads. I place an external tooth lock washer between the strap and head when building my cars. Also between the strap and dash panel.
len47merc |
09-11-2021 @ 4:35 PM
Smart.
Steve
TomO |
09-14-2021 @ 7:49 AM
I don't know why you would clean a grounding cable. If it has corrosion, the best solution is to replace it.
