EFV-8 Club Forum / 1940 Ford Discussion / Correct 40 fuel pump
Posted By Discussion Topic: Correct 40 fuel pump
plymboy
05-25-2020 @ 11:59 AM
I have two thta are close to the same but the outlet hole is slightly higher on one....which would be correct?....and yes both pumps have the wing shut off/ drain valve
05-25-2020 @ 2:14 PM
The outlet should be about 3/16" or so lower than the inlet. The top cover should have NO "tabs". In other words, the lip is smooth all the way around.
ken ct.
05-25-2020 @ 4:13 PM
Correct on both counts Mike !! ken ct
