EFV-8 Club Forum / 1940 Ford Discussion / Backing plate bolts
Posted By Discussion Topic: Backing plate bolts
RELDDS
12-28-2018 @ 5:09 PM
Is the correct placement of the 1940 front and rear backing plate bolts with the heads facing inward?
12-29-2018 @ 5:39 AM
You will note that the authentic bolts have a square head that when "seated" inside the brake area, won't be able to turn as they will be set against the axle housing.
RELDDS
12-29-2018 @ 8:15 AM
Yes sir! Definitely noted why bolts have square heads. Thanks Mike! Have a healthy, happy, and safe 2019!
