32v8 | -- 01-20-2013 @ 8:45 PM |
I am trying to identify my brake pedal as a 32 pedal. it does not have a B part number like the clutch pedal that I can see. It does have the X cut out on the pedal mounting surface. It measures a little over 13 inches from center of shaft to forward the 90 degree pedal. there is a m8 pressed in the brake pedal. Thanks Jack
doylez286 | -- 02-17-2013 @ 9:19 AM |
I am working on my brake and clutch pedals. My brake pedal was cut off and I had to lengthen it. I never noticed any letters or numbers but I'll look closer and let you know.I'll look tomorrow. I'll get some dimensions for you.There are some good pictures in The 932 Ford Book on page 4-13. Doyle
doylez286 | -- 02-18-2013 @ 7:05 PM |
I checked my pedal and it is 13.25 inches but like I said it was cut off and I had to estimate how long to make it.The clutch pedal was closer to 13 inches if you measured square from the center line to the bend. The only marking on my petal is a #2 about half way up the pedal. Hope that helps. Doyle
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=5637 |
