FFracer | -- 10-28-2011 @ 8:17 AM |
Hi all, new to the forum so I hope this is the right place to post for the 33. The gauge i have is a combination amp and oil pressure, amp works fine but the O/P gauge just has a red "OFF" when running or not. there are two electrical lugs on top of the gauge one wire is going to a sending unit which has two spades, the other has nothing connected. So the sending unit has two male spades I am thinking So the sending unit is a switch, right? one wire to the gauge (actually a switch also) the other to batt. voltage. Then the gauge has that one wire from the sending unit then the other lug to body. Sound right??? It's a positive ground car so I just am not sure. Thanks for any input. FOUND THE RIGHT FORUM ![]() Chris This message was edited by FFracer on 10-28-11 @ 8:37 AM
supereal | -- 10-29-2011 @ 1:09 PM |
See the response in the general discussion.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=3906 |
