FredF | -- 07-20-2011 @ 6:02 PM |
What is a safe method/product to clean surface rust from a refinished flywheel? Thanks in advance.
supereal | -- 07-21-2011 @ 5:18 AM |
We use a Scotch Brite wheel to clean all flywheels before the clutch is attached, even if it wasn't resurfaced. It breaks the glaze, and gives a uniform surface. We recommend that all flywheels be taken to a machine shop for a trip thru the resurfacer. Given the clutch shudder typical to most old Fords, it is a very good investment. One caution. Do not use Scotch Brite to clean gasket surfaces. Any loose fibers can quickly ruin bearings. A good solvent after the wheel, or resurfacing is either a carb or brake cleaner aerosol. They will remove all traces of oil. This message was edited by supereal on 7-21-11 @ 5:21 AM
FredF | -- 07-21-2011 @ 2:09 PM |
And thank you, again.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=3432 |
