Peterooster | -- 05-21-2011 @ 5:19 PM |
Does any one have a picture of 32 pickup pans/splash guards so I could build them or buy them if they are avaiable. These are the pans between the frame and four cylinder engine. Pete
trjford8 | -- 05-21-2011 @ 7:31 PM |
To my knowledge the pickup used the same pans as the 4 cylinder passenger car. Hopefully someone who is working on 4 cylinder car can post a picture of the pans.
CharlieStephens | -- 05-21-2011 @ 8:52 PM |
Here is a picture of the 4 cylinder pans. These are early, later pans had a slit under the steering box to clear the brake rods. Better to buy than try to build. My guess is that you could buy a good set for about $300. If you want to build, get back with me. Charlie Stephens This message was edited by CharlieStephens on 5-21-11 @ 9:49 PM
Peterooster | -- 05-23-2011 @ 4:24 PM |
Thanks for the pictures, they might be tricky to build. pete
jim5618 | -- 06-12-2011 @ 2:24 PM |
Mine look similar but has a slot in them.
CharlieStephens | -- 06-18-2011 @ 11:05 PM |
Jim, The pans with the slot are correct for cars after June according to "The 1932 Ford Book". There is a good photograph on page 5-7 of the book. Charlie Stephens
Peterooster | -- 06-19-2011 @ 5:21 PM |
Thanks for the info, I do have the Ford book, guess I better open it. Pete
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=3103 |
