duecetwo32 | -- 04-24-2011 @ 11:26 AM |
DOES ANYONE KNOW THE EASIEST WAY TO REPLACE A LEFT DOOR WINDOW GLASS. i ALREADY HAVE THE REPLacement glass but not sure how to remove old window.
32inxs | -- 04-24-2011 @ 3:38 PM |
Just did this a month ago. the trick is to take both side chsnnels out, thae the riser assembly out and it will come right out through the bottom of the door. be sure to keep track of which screws came out of where because there are different sizes. do not use riser handle without putting in the pin as it will detonate.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=2959 |
