older rodder | -- 12-27-2010 @ 5:16 PM |
Hi.... I am new to this forum ..... I need help with the k or x frame of the 32 .... I need the measurment from where it starts to where it ends .... I'm using a 350 sb ......Is there anywhere I can look it up on the internet ???? Thanks, Vince ( Bradenton , Fl, )
trjford8 | -- 12-27-2010 @ 7:27 PM |
Go to; www.wescottsauto.com. There is a line drawing and dimensions of the 32 frame on their website. Go to the left menu and go to the tech section. This message was edited by trjford8 on 12-27-10 @ 7:29 PM
older rodder | -- 12-28-2010 @ 5:33 AM |
trjford8 ...... I have looked at Westscotts , I was just wondering if there was someplace i could look with a little more detail...... thanks, vince
CharlieStephens | -- 12-28-2010 @ 10:37 AM |
Since the K member will probably be removed when installing a SBC what do you need the measurement for? Knowing what you need the measurement for might make it easier. You should also post on HAMB as they are into the modified vehicles http://www.jalopyjournal.com/forum/. Charlie Stephens This message was edited by CharlieStephens on 12-28-10 @ 10:37 AM
older rodder | -- 01-10-2011 @ 7:49 PM |
Charlie Stevens, If the K frame is welded in , why would you remove it to install the eng. and trans ???? Isn't the purpose of the K frame the strength of the rails and all the parts to be added ????? .....Thanks, Vince ( Bradenton , Fl, ) IN GOD WE TRUST
CharlieStephens | -- 01-10-2011 @ 8:42 PM |
If you are planning on running an early Ford closed drive transmission then there is no need to remove the K member. The reason I said probably is that I assumed you were going to run a late model trans that would require the K member to be removed or extensively cut up. I would not recommend an early Ford closed driveline with a 350 SBC. On the other hand I wouldn't recommend a SBC (unless I was posting on HAMB). I like flatheads or a 4 banger. Charlie Stephens
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=2353 |
