jgzavar | -- 05-12-2021 @ 7:04 AM |
What is procedure for timing distributor to engine on 32Ford
TomO | -- 05-12-2021 @ 7:59 AM |
You will need a timing fixture or a distributor machine to get the timing correct. The distributor only fits on the engine one way and if both sets of points are set correctly, the timing will be correct. Tom
3w2 | -- 05-12-2021 @ 5:51 PM |
The procedure is entirely different for the fours and V8s and you did not mention which you were asking about. A timing fixture is not used in the procedure for the fours, for example.
TomO | -- 05-15-2021 @ 8:29 AM |
3W2, thanks for correcting my post. Correct information is always better than partial information. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=14824 |
