Engine24 | -- 10-18-2017 @ 8:52 AM |
I believe I may need a new battery My horn only humms instead of a full blow Also Weak starting unless on trickle charge Battery a few years old Will any 6 volt battery replace the battery in my original 32? Thanks
3w2 | -- 10-18-2017 @ 6:22 PM |
When you indicate 'stock' I am assuming that your car has the original carrier for the battery. You will restricted to a battery no larger than can fit in the carrier. The other restraint is the height as the battery must fit below the floorboard. NAPA carries a 6 volt battery that will fit within those restraints. The original battery was 7 1/8" x 9 3/16" (width) x 7 13/16" (height). The NAPA battery is slightly higher than the original, but still fits beneath the floor board.
Engine24 | -- 11-04-2017 @ 10:32 AM |
Yes. The battery is housed under the floor Thank you for that very useful information!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=11288 |
