36fordor | -- 08-16-2016 @ 5:37 PM |
Am considering duals for 35 Ford coupe. Would appreciate any recommendations, tips, info regarding headers, mufflers, pipes. Thanks.
ken ct. | -- 08-16-2016 @ 7:33 PM |
Nobody makes a fit right on system.Your better off having a local muffler shop bend a set for you. Use stock manifolds (no advantage to headers). Hardest pipe to make is the left head pipe. I had a old one to use for a pattern. The flange must be welded at the correct angle and pipe must clear steering box and battery. BTW I run straight pipes on my 36 coupe (n0 mufflers). Don't ask how I know commercial systems don't fit. ken ct.
JM | -- 08-23-2016 @ 8:18 AM |
I bought a set of Red's Headers and dual exhust pipe kit to install on a 35 coupe. This was after the existing owner of RH's worked out and supposedly corrected the fit problems with the exhaust pipes he included with his kit. I have not installed this yet so can't tell you how this whole system will fit together, but I am hoping for the best here. John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9991 |
