Flatbob | -- 08-03-2016 @ 3:16 PM |
The cone shaped springs that go between the door and the door panel face which way, pointy side towards the door or toward the door panel?
nelsb01 | -- 08-03-2016 @ 7:51 PM |
I believe that the small spring end goes toward the door panel. The small end would then support the round end of the door handle and the window crank handle without damaging the panel. Stand corrected..... I should have never thought logically when it comes to Henry and his thought process. This message was edited by nelsb01 on 8-4-16 @ 8:57 PM
trjford8 | -- 08-04-2016 @ 7:13 AM |
Large end towards the door panel. The large end spreads out the pressure against the door panel and the escutcheon. Using the small end against the handle does not allow the escutcheon to fit tight against the panel.
TomO | -- 08-04-2016 @ 7:23 AM |
I agree with TRJFord8 Tom
Flatbob | -- 08-04-2016 @ 8:26 AM |
Thanks guys, large end toward the panel it is then.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9955 |
