tommyleea | -- 07-18-2016 @ 7:59 AM |
Just picked up a 1953 Ranch Wagon, with no rear brake drums. I can't find them anywhere. Are they supposed to be 11 x 1 3/4, and if so would the ford truck brake drum work? All the ones I look up say except for wagon. Tried MACs and Dennis C, with no luck. Thanks
carcrazy | -- 07-18-2016 @ 2:54 PM |
The front and rear brake drums on the '53 station wagons and sedan deliveries are 11" diameter. The wagons and deliveries use the same rear axle as the 1/2 ton pickups of the same year. The rear brakes on the wagons use wheel cylinders with 15/16" diameter. Hope this information helps.
woodiewagon46 | -- 07-18-2016 @ 4:10 PM |
Tommy, a company called Master Power Brakes, 888-251-2353, www.mpbrakes.com, had brake drums for an 8' Ford rear I was working on. All they do is brakes.
tommyleea | -- 07-18-2016 @ 8:29 PM |
Thanks for the info...just seems odd that I can't just look up brake drums for my car, and have the info show up.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9893 |
