twostickmutt | -- 07-08-2016 @ 1:26 PM |
my '39 has an aluminum radiator in it that was put in before i bought it. it's sitting on kind of an angle and i want to straighten it out some. my question is how much space should there be between the fan and radiator ? thank you.
ford38v8 | -- 07-08-2016 @ 2:07 PM |
Fan should be as close as possible to the radiator for maximum efficiency. This assumes that there is no shroud on your non-stock radiator. Consider the normal movement of the engine during operation also. Alan
twostickmutt | -- 07-09-2016 @ 10:23 AM |
thanks alan.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9856 |
