twostickmutt | -- 07-06-2016 @ 4:43 AM |
was wondering if anyone has used NGK B4L plugs in a 59 a.mine is stock and 6 volt. was told they maybe too hot for the stock motor. thanks
ken ct. | -- 07-06-2016 @ 6:05 AM |
I used a set in a 36 and were junk , went back to Champ and back to no trouble again. ken ct.omo
twostickmutt | -- 07-06-2016 @ 8:09 AM |
thanks ken !
Grant | -- 07-07-2016 @ 4:27 AM |
Agree with Ken. Recently put a set of Champion D21 plugs into our '36. Work great.
37 Coupe | -- 07-07-2016 @ 6:04 AM |
The '36 Ford replys would be referring to a different plug or at least plug size if original engine. I have succeesfully used the NGK plug in 59 engine as originally post asked .I had problems with Champions as made today and also Autolites but NGK have held up last 8 years for me. Better replies may be from some posters who have the same engine 59 AB and put lots of miles on their vehicles like Old Henry or others.
flathead4rd | -- 07-07-2016 @ 6:56 AM |
I have NGK B4L plugs in my 8-BA and have had better luck with them than Champions. Also the Autolite 216 was better also.
TomO | -- 07-07-2016 @ 7:05 AM |
The cross reference for the Champion H10 to NGK is B6L. The B4L is a slightly hotter plug, designed for slow speed driving and should work fine in a 59A engine. Here is a link to NGK's explanation of heat range. http://www.ngk.com.au/spark-plugs/technical-information/heat-range-explanation Tom
twostickmutt | -- 07-07-2016 @ 7:05 AM |
thanks for all the replies. i think i'll try a set of b4l's. most can happen is i don't like them i guess. thanks again.
ken ct. | -- 07-07-2016 @ 7:36 AM |
Yes 36 plugs are 18 mm and 59 plugs are 14 mm I know that and the NGK's were n/g on this engine.. I do use ngk's in my motor cycle and work ok , go figure ??? ken ct.
37 Coupe | -- 07-07-2016 @ 8:58 AM |
Tom O you are correct.I knew I was using an NGK plug but had to look to see they are the B6L ones. This message was edited by 37 Coupe on 7-7-16 @ 8:59 AM
twostickmutt | -- 07-07-2016 @ 12:57 PM |
good post tom thank you
Drbrown | -- 07-08-2016 @ 6:12 PM |
My 59AB has been running on a set of Champion H11's for many years. They burn clean given the type of driving I do.
42guy | -- 07-09-2016 @ 4:44 PM |
I have been using the B6L NGK plugs for 5 or 6 years. Still using the same plugs I put in.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9852 |
