gmharlow | -- 07-05-2016 @ 3:00 PM |
What is the correct pressure for the radiator cap on a 1936 Ford passenger car? I find them available in 4-pound and 7-pound varieties.
MG | -- 07-05-2016 @ 3:07 PM |
1936 Ford's did not have pressurized cooling systems from the factory....
gmharlow | -- 07-05-2016 @ 3:18 PM |
So I guess either cap would work? I find them for sale in the 4- or 7-pound versions.
MG | -- 07-05-2016 @ 3:25 PM |
Again, the stock radiator was not manufactured to be pressurized - they tend to become 'bulbous' and burst on pressures over 3 pounds. Skip Haney sells a 3 pound device (pressure relief valve) that attaches to the overflow tube and it requires a cap that seals. In most cases though, a 4 pound cap will work OK.... This message was edited by MG on 7-5-16 @ 3:52 PM
pauls39coupe | -- 07-05-2016 @ 5:34 PM |
Your stock 36 had an overflow tube which allows excess pressure to escape. The stock cap was not pressurized, it just acted as a seal. Adding a pressure cap alone will do nothing because the pressure will just escape from the overflow. Skip's valve seals the overflow tube to 4 psi, then your 4psi cap will do its job.
gmharlow | -- 07-06-2016 @ 6:31 AM |
Thanks to all. That solves my problem.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9845 |
