MikeRhodes | -- 06-27-2016 @ 1:49 PM |
I've got a Borg-Warner overdrive cantilevered off the front of my differential. I think it's a hokey set-up and causes a hard bump/knock whenever I drive over even relatively minor bumps. I have a 3-speed with the last version of the original V8 (1953) engine. ==> Is there a better overdrive I can install? I'm looking at the Mitch*ll overdrive and it seems to be pretty clean and an easy install. However, it seems to be primarily for the Model A's -- though they do advertize a V8 version. Anyone out there have suggestions or comments regarding the Mitch*ll Overdrive for the V8? Mike Rhodes
40cpe | -- 06-28-2016 @ 6:50 AM |
Is the OD unit hitting the car floor on bumps? Many report having to cut a pocket in the floor even when using the Mitch*ll unit. I don't know if the clear on a '34 or not. If clearance is the problem, cut the floor now and save the trouble/expense of the change. The BW unit is the better unit, IMO, because of the electric shifting.
trjford8 | -- 06-28-2016 @ 1:44 PM |
A club member in my regional group has a Mitch*ll in his 34 roadster and swears by it. He easily cruises at 65 mph. There's lots of them out there and I have never heard anything negative about them.
40cpe | -- 06-28-2016 @ 2:00 PM |
I'm not implying that there is anything wrong with the Mitch*ll. I just like the electric shifting of the BW. IF his noise is from a clearance issue, some have had it with the Mitch*ll, too.
MikeRhodes | -- 06-29-2016 @ 9:35 AM |
Thank you both for your views. Yes, the OD bangs against the floor. I'll look at it more carefully and see what space I might be able to create. I am aware that many like the Borg-Warner and Mitch*ll has a very good reputation as well. I think the most cost effective approach at this point is to cut-out some space in the floor.... I'll report back on this, though it will take a bit of time. I've got a dozen other projects in front of this. MikeR
trjford8 | -- 06-29-2016 @ 1:19 PM |
40cpe, I didn't feel that you were implying anything was wrong with the Mitch*ll. It looked to me that you just a had a preference for the BW.
40cpe | -- 06-29-2016 @ 1:40 PM |
Thanks! All's well.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9817 |
