murphy1941 | -- 06-22-2016 @ 10:41 AM |
When turning into a street sometimes if there's a bump in road or road unevenness I hear a clunk in the rear. Is that something in the differential or shocks? Any feedback appreciated as to what to look for. John
shogun1940 | -- 06-22-2016 @ 2:04 PM |
I would check the shock mounts first, and the spring shackles . If that doesn't work put the wife in the trunk and remember to let her out.
murphy1941 | -- 06-22-2016 @ 8:49 PM |
Thks appreciate john
DD931 | -- 06-24-2016 @ 9:21 AM |
Make sure the rear hubs are properly tightened to the axles!!!
murphy1941 | -- 06-30-2016 @ 7:57 PM |
What are the tightening specs or is it hard as you can then back off as necessary to put cotter in? Thanks john
murphy1941 | -- 06-30-2016 @ 7:59 PM |
I jacked up rear and pulled on each wheel. The right had enough play that I could feel it but the left had no play?
supereal | -- 07-01-2016 @ 5:19 AM |
Be sure the rear spring clips holding it to the crossmember are tight, and the head of the tie bolt in the center of the spring is firmly seated in the hole of the crossmember. If this doesn't fix the noise, you may have either a broken tie bolt or one or more broken spring leaves. It is almost impossible to find the breaks without removing and disassembling the spring
murphy1941 | -- 07-19-2016 @ 7:21 PM |
Thais for input, tight Ned right rear seems to be ok now. Will see after I tak ear out a few times. Thks again john
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9803 |
