deluxe40 | -- 06-21-2016 @ 12:09 PM |
The driven gear on the transmission end of my speedometer cable has 21 teeth and my speedometer reads fast. I believe the rear end is a 4.10. How many teeth should the driven gear have?
TomO | -- 06-22-2016 @ 7:55 AM |
21 tooth driven gear is correct for the 4.10 rear end used with a stick shift. Tom
flathead4rd | -- 06-22-2016 @ 8:37 AM |
What transmission do you have? Standard or overdrive?
deluxe40 | -- 06-22-2016 @ 9:12 AM |
The transmission is overdrive. Now I'm stumped. If anything, with the correct gear the speedometer should read slower than the car is going because the 7.10 tires are oversize. I didn't count the teeth on the gear, but it has "21" on it. Thanks to TomO for the information. Saves me some frustrating trial and error.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9798 |
