rdofloor | -- 06-21-2016 @ 12:08 PM |
I took the light switch apart to work on the horn and was replacing the plunger and took it off. I marked the wire with masking tape but when I went to replace the wires the tape stuck to each other and came off. any help would be thank full Roger Oliver
TomO | -- 06-22-2016 @ 8:00 AM |
Here is a link to the wiring diagrams. They will be helpful if you can still determine the wire colors. http://vanpeltsales.com/FH_web/flathead_drawings_electrical.htm Tom
6lucky13 | -- 06-22-2016 @ 1:06 PM |
Maybe this will help. Kerry
rdofloor | -- 06-25-2016 @ 8:22 AM |
thanks Kerry got it fixed. Roger
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9797 |
