davem | -- 06-13-2016 @ 4:27 AM |
Restoring a 1937. Looking for the mechanical brakes backer plates. I believe that the 37 and 38 brakes are identical. Does anyone out there have them or know who I could contact to buy them. Thanks.
40 Coupe | -- 06-13-2016 @ 4:40 AM |
Check Southside Obsolete web site and give Fred a call.
ford38v8 | -- 06-13-2016 @ 10:28 AM |
Dave, congrats on your decision to go original. Yes, '37 & '38 are identical. Good luck and consider going with floaters and a dummy adjusting nut. The nut serves as a dust cover, and is removed to expose the star adjuster within. The nut itself being original, the conversion is undetectable on the Concourse, and makes a world of difference in operation. Alan
coup | -- 06-16-2016 @ 10:18 AM |
I have what I believe is the center assy, that pull the cables to each wheel. If you need it you can have it for the shipping cost. e-mail me. wrnm59@q.com
davem | -- 06-24-2016 @ 4:30 AM |
Thanks for the help. I have located all the parts and pieces to put the mechanical brakes back on the 37 except for one item. I am now looking for the rear cable retainers (clamps). If I have it correct these two brackets were riveted to the frame. Anyone have a direction to look for these. Thanks.
nelsb01 | -- 06-24-2016 @ 11:50 AM |
Cant help you with the rear cable retainers, but Roy Nacewicz does sell a great set of fake rivets (rivet head and threaded shaft and nut) when you get that far. If I understand you correctly, you are using a original 1937 frame, why wouldn't the rear cable retainers be there? When converting to hydraulic there would be no need to 'cut' those off.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9772 |
