Grant | -- 05-29-2016 @ 9:09 AM |
What lubricant should I be putting into the small oiling hole at the top of a stock 1936 V8 distributor? How much? How often?
nelsb01 | -- 05-29-2016 @ 9:44 AM |
I use a good weight oil. I oil once in the spring and then before every long trip. One or two drops is all you need.
joe b | -- 05-29-2016 @ 1:01 PM |
I use 3 in One SAE 20 for Electric Motors. It comes in the small plastic container (3 oz.) as does the other weight. Available most anywhere. I lube mine the same as nelsb
Grant | -- 05-30-2016 @ 5:01 AM |
Thanks very much, gentlemen. Sounds like that 3 oz container should fit nicely into a rumble seat toolbox.
TomO | -- 05-30-2016 @ 8:05 AM |
The 3 in 1 oil is a little too light for the oilite bushings. Ford recommended engine oil. I use 30w and lube it and the generator once a month during driving season. Tom
40 Coupe | -- 05-31-2016 @ 5:07 AM |
Engine oil, not 3 in 1.
Grant | -- 06-01-2016 @ 5:39 AM |
Okay. Thank you.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9729 |
