FLTHDCPE | -- 05-23-2016 @ 9:06 PM |
I have a 41 with a clock and a short connector wire with a ground terminal. Is there a wire in the harness to connect the light and what color code am I looking for? I don't see a spare wire. Also have a "ignition switch lamp" that lights with the park lights but goes out when you select the head lights.? Don't think that is suppose to happen. Thank You in advance for your input. Steve. Thank You.! Steve
Drbrown | -- 05-23-2016 @ 9:54 PM |
Yes, the ignition key light and front parking lights are suppose to go out once you turn the headlights on. A good harness should include a wire lead for it, same color-code as instrument lights ? Blue-Red ?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9701 |
