silverchief | -- 05-15-2016 @ 8:58 AM |
I have Super Tech 85W-140, Valvoline 80W-90, and Amsoil 75W-90 in my garage. Any problem in I accidentialy mix one with the other?
Drbrown | -- 05-15-2016 @ 8:57 PM |
Would help if the containers list ingredients so you had some info to compare. Mixing the similar grades "might" be okay but others here could advise better.
len47merc | -- 05-16-2016 @ 4:34 AM |
As a matter of practice I never mix synthetics (Amsoil) with regular oils (Valvoline or SuperTECH, the others you referenced). Additionally, depending upon the application (year, model, rear-end versus transmission versus steering box, etc.) you may see less than optimal shifting performance &/or more leakage if you've mixed weights with the regular oils. If in the rear-end you may not achieve the minimal level of lubrication required for effective performance as designed by Ford. For our EFV8s I stick to the standard oils and weights as specified in the SHOP MANUALS, Motors Manuals and Service Bulletins. Steve This message was edited by len47merc on 5-16-16 @ 4:38 AM
Drbrown | -- 05-18-2016 @ 10:18 PM |
To improve gear shifting I use StaLube brand 90w in my tranny and 140w in my OD and rear end. The condition of your drive train (i.e. leaking seals, condition of gears) affect your choices.
silverchief | -- 05-19-2016 @ 9:51 AM |
Thanks guys. I only use the Amsoil in my steering gear box, and the other two in my trans and differential.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9672 |
