dggohl | -- 05-12-2016 @ 7:32 AM |
I have a mechanic replacing my 239 with a Merc 255. The first thing he noticed was that the transmission is not going to work with existing. Can the 239 tranny be used here? Also, he said that there's a some kind of plate that has to be used in order to make it usable as well. The replacement motor is a 1953 Merc, into a 1952 Mainline. Thanks. This message was edited by dggohl on 5-12-16 @ 7:44 AM
trjford8 | -- 05-12-2016 @ 7:39 AM |
It would help if you give us the year of your car.
TomO | -- 05-12-2016 @ 4:10 PM |
The blocks are identical. The Merc uses a bell housing adapter that allows it to be mated to the earlier transmission or to the Mercury transmission. The Ford uses a different bell housing. Your mechanic need to remove the bell housing from your old engine and replace the Mercury bell housing with it. Tom
trjford8 | -- 05-12-2016 @ 5:09 PM |
Whoops, I should have read the total post. Missed the mainline part. Duh!
dggohl | -- 05-12-2016 @ 5:21 PM |
Thanks Tom, that will be a big help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9658 |
