ldh2176 | -- 04-21-2016 @ 1:53 PM |
My 41 ford fordor is almost finished. Thanks for all the help I have gotton here. Here is my current problem but it a little away from the usual cars and trucks on here. I have an 81 ford courier pickup that is blowing the regulator fuse. A short somewhere. I have unpluged the alt, regulator and changed out the ignition. Ihave taken all fuses out of the fuse box all of which still leads to a blownregulator fuse. I ran a new jumper wire from the ignition switch to the fuse box and the fuse still blew out. This happens as soon as I turn the ignition on not t
TomO | -- 04-21-2016 @ 7:18 PM |
You may have a bad alternator. you may get better help on the Courier Forum http://fordcouriercollector.com/ Tom
trjford8 | -- 04-22-2016 @ 8:02 AM |
Sounds like a bad alternator or a main wire in the system that is going to ground. Did you replace the wire from the regulator to the alternator? Remove the alternator and take it to a parts store that can test it.
ldh2176 | -- 04-27-2016 @ 8:53 AM |
The alterantor checked good. Ford courier site is under updating and not much help. I did find a short in a plug in connection near the battery. The fuse is now good but my volt gauge does not register anything. I am thinking maybe now the ignition module might be bad. Thanks.
ldh2176 | -- 04-27-2016 @ 8:54 AM |
I will check the wiring closer to the alt. Thanks for input.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9604 |
