coupeman | -- 04-16-2016 @ 9:02 AM |
I have a 48 ford super deluxe with a single hole in steering column bracket for my ignition switch, is there a different bracket to mount a ignition switch light, the wiring harness under the dash has light socket for that area.
fla48 | -- 04-18-2016 @ 5:55 PM |
There is a hole in the dash above the ignition switch. Behind this hole is a socket for the light to mount in. Should work.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9590 |
