ftda1941sd | -- 04-12-2016 @ 6:05 PM |
Does the '41 utilize the stainless steel ring part # 6a-3628? Mine didn't/doesn't have one but I see it listed at Mac's, Dennis Carpenter and others. If so does it go tight against the horn ring? Thanks Bob.
42wagon | -- 04-13-2016 @ 10:15 AM |
You have me a little confused. I assume you have a chrome plated diecast horn ring and I assume you have the plastic center horn button (for lack of a better name). For the horn button to attach to the horn ring you need the retainer part number 6a-3628. The button is held in the retainer and the "ears" on the underside bend into slots in the ring. I don't know how you managed to hold the pieces together without it.
ftda1941sd | -- 04-13-2016 @ 12:47 PM |
Yes I have the chrome plated cast horn ring. I also have the 3 tab ring attached to it via 3 insulated screws and a spring. I have no plastic part. I'm trying to find out what I'm missing and may still need. Thanks Bob A.
42wagon | -- 04-13-2016 @ 1:45 PM |
Well without a picture I'm still in the dark as to what you have but in the center where you would expect to find a horn button there should be a large round piece called a horn button in Mac's catalog and having a part number like 6a-3627-B. If you have that, you probably have everything. If not I don't know where to find one for a 41.
41-42fordadvisor | -- 04-14-2016 @ 6:56 AM |
The ring part number 6A-3628 is only used on 1942-1948 Ford Super Deluxe horn rings. The 1941 Ford Super Deluxe horn ring does not have a plastic center. Fred Killian
TomO | -- 04-14-2016 @ 4:02 PM |
The easiest way to find out what you are missing is to post photos. Tom
ftda1941sd | -- 04-14-2016 @ 5:23 PM |
Thanks everyone for your assistance. C & G listed that part as a 42-48 application. The other vendors had it for 41-48. Fred thanks for clearing that up. Bob A
mrtexas | -- 04-14-2016 @ 8:25 PM |
Here is a picture: --- This message was edited by mrtexas on 4-14-16 @ 8:26 PM
engine | -- 04-22-2016 @ 10:14 AM |
If you have trouble getting one you can try Baxters Ford parts in Lawrence Kansas
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9581 |
