mlevan | -- 04-07-2016 @ 9:11 AM |
could anyone tell me the correct place to put return throttle spring on 1951 ford v-8? mine has spring on carb.linkage but no where to fasten other end.
deluxe40 | -- 04-07-2016 @ 9:42 AM |
The only return spring I see on my '51 V-8 standard shift is the one wound around the throttle linkage at the bend under the oil filter.
mlevan | -- 04-09-2016 @ 6:59 AM |
thank you much,found it
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9559 |
