jwitt | -- 03-30-2016 @ 2:41 PM |
What is the engine RPM per mile per hour in top gear for a '36? Stock rear axle ratio as far as I know and 6.50-16 tires. Thanks all, John Houston, Tranquility Base here, the Eagle has landed.
woodiewagon46 | -- 03-30-2016 @ 3:22 PM |
MPH, times gear ratio, times 336, divided by tire diameter will give you RPMs
shogun1940 | -- 03-30-2016 @ 3:59 PM |
THER is an app from tremec trans. That gives you a calculator for tire size,gear ratio ect. It also lets you figure out pinion angle and you can use it as a level
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9531 |
