MICHV8 | -- 03-28-2016 @ 6:16 AM |
Speedway offers this coil...why would a 12 volt system require a resistor, but not a 6 volt resistor? Pertronix 45011 Flame-Thrower II Ignition Coil, 6 Volt, 0.6 Ohm For a 6 volt system it does not require a resistor. If used with 12 volt point system it should have a 1 OHM resistor added.
TomO | -- 03-28-2016 @ 8:23 AM |
The coil has sufficient internal resistance in the primary circuit for a 6 volt system, but not for a 12 volt system. Tom
MICHV8 | -- 03-29-2016 @ 5:22 AM |
Thanks again Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9523 |
