custom | -- 03-16-2010 @ 6:31 PM |
I have a 52 customline w/fordomatic trans and it also has a leak. Are there any common repairs that I may be able make w/out looking for a trans shop right away? It seems to shift and engage into gears o.k. but it leaks while sitting.
supereal | -- 03-17-2010 @ 6:03 AM |
If the Ford-O-Matic has visible leaks anywhere except the pan, it is a job for the pros. The pan gasket can be changed, and the fluid screen cleaned. Be careful to torque the pan bolts to 10-13 ft. lbs only. Anything else is not a DIY project
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=952 |
