engine | -- 03-25-2016 @ 3:32 PM |
Can anyone tell me if the 1940 heater and the 1941 heater are the same schematic for the layout on the firewall. I am installing one and have to drill the holes. Also does the end cap on the ignition switch pull off with a lot force? Tried to pull it but not sure how much force is needed.Thanks
kubes40 | -- 03-25-2016 @ 6:55 PM |
Firewalls are very different between a '40 and a '41. So, template for installing heater is by necessity very different. The "end cap" can be pried off (carefully) but you will need to get under its edge / rim. That requires disassembling the mechanism. Mike Kubarth
engine | -- 04-02-2016 @ 8:51 AM |
Mike, Thanks for getting back with me. Do they have a drawing of where the holes go on the firewall.
kubes40 | -- 04-02-2016 @ 11:28 AM |
I'm certain there is a template out there somewhere. Unfortunately I do not have one for 1941. Sorry...
engine | -- 04-04-2016 @ 1:39 PM |
Thanks again
Drbrown | -- 04-05-2016 @ 11:41 PM |
IF YOUR ARE CONNECTING YOUR HEATER TO YOUR IGNITION SWITCH, AND YOUR CAR STILL HAS ITS STOCK WIRING SYSTEM, BEWARE OVERLOADING THE IGNITION SWITCH BECAUSE IT IS NOT PROTECTED BY A CIRCUIT BREAKER OR FUSE. HOWEVER, YOU CAN INCORPORATE A FUSE INTO THE WIRING.
engine | -- 04-09-2016 @ 12:13 PM |
Good to know, what size fuse would be needed?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9513 |
