carioca | -- 03-25-2016 @ 1:18 PM |
I just purchased a 1950 4 door ford customn. The patent plate reads B0DA 177502. This is also the serial number. IO am ubnable to decode this serial. Can anyone help? Carioca
joe b | -- 03-25-2016 @ 3:34 PM |
Try the Vanpelt site. http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm This site has a lot of info. You should find the answer there. Let us know.
nelsb01 | -- 03-25-2016 @ 5:21 PM |
What you need is the 1949-1951 Ford Book that the club publishes. It is available from the online store. It will be a great asset to owning your Ford. But, I will give it a shot .,............ B = V-8 0 = 1950 DA = Dallas assembly 177502 is the sequence number for production (it started at 100001, so your vehicle is the 77501 one produced. Hope this helps. You should also have a cowl code that will give you the body code, color code, Upholstery code. This message was edited by nelsb01 on 3-25-16 @ 5:36 PM
carioca | -- 03-26-2016 @ 7:37 AM |
Thank you. I think you are correct. Carioca
carioca | -- 03-26-2016 @ 7:38 AM |
tries Van Pelt. Not very helpful. Carioca
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9512 |
